New 2018 Porsche Cayenne
#61
Also, it is Porsche's philosophy (and all German luxury brands) to gouge you on options. But I predict this time, there is going to be a package, like the Panamera's (instead of individual options):
Package contents:
Porsche InnoDrive incl. Adaptive Cruise Control (ACC) and Traffic Jam Assist
Lane Keep Assist (LKA)
Night Vision Assist
Package contents:
Night Vision Assist
Still, no emergency stopped vehicle or pedestrian braking or parking assistance. Given their appeal in the grocery-getting set I'm surprised this hasn't been implemented.
BMW's new surround view display is pretty clever looking (basically showing a view from a few feet away instead of just top-down). I'm actually coming around to using the surround camera features a bit more, if just to avoid scraping the rims during parking, or getting centered in the every-narrowing paint lines some parking lots are using. I wouldn't mind having a more direct way to select it instead of digging through the menus or dedicating the diamond button on the steering wheel.
Speaking of which, the new 958.3 looks to be getting the new steering wheel too, with a few more infotainment control features on it. That's one option I wouldn't mind paying a bit for if it could be retrofit onto my '17.
#62
http://www.porsche.com/international...nt/night-view/
Night View provides the driver with information even beyond the range of the headlights. An infrared camera detects pedestrians or large wildlife before they are illuminated by the headlights. A thermal image in the instrument cluster warns the driver: the detected person or animal is highlighted in yellow – or in red and accompanied by an audible signal if within the critical range in front of the vehicle. In combination with PDLS Plus, the marker light function briefly flashes the headlight at the pedestrian on the kerbside or in the carriageway three times to alert the driver’s attention.
#63
Likewise the 1st gen had interim updates as well resulting in two versions, but they got separate number designations (955 & 957), but Porsche refers to them as Cayenne E1 and Cayenne E1 II respectively.
So, that brings us to the 2019 which has been referred to as the 3rd gen of the Cayenne. So what's it's number designation?
(Man I need to get a life!)
#66
From an intro video it was stated that while the wheelbase remains the same the front and rear has been extended. This is where the additional rear cargo room comes from. Disappointing as two of my three Cayenne weak points are the approach and departure angles.
#67
Received 1,271 Likes
"Wading depth is 20.7 inches, and the Cayenne can attack boulders of a reasonable size with an approach angle of 27.1 degrees, a breakover of 21.1 degrees, and a departure angle of 24.1 degrees."
If these numbers are for normal suspension, this is actually an improvement. If these are for the air suspension in its highest setting, then it would be a small step back.
I'm optimistic that it's the former. The bumpers and misc plastic bits on 2019 model seem to be less extending downward than on the current one, which would result in better angles even with slightly longer overhangs
#69
"high-performance Porsche Surface Coated Brakes (PSCB) consist of a cast-iron disc with 70 micrometers of tungsten-carbide coating. Once bedded in, the surface of the brakes shine like a mirror, but they have better performance over steel brakes, with less wear and a longer life. Karl Heess, Porsche director for product line SUV, says PSCB reduce brake dust by as much as 50 percent (over conventional steel brake discs) and extend the life of the disc by up to 35 percent. They are more expensive than steel discs but still up to 50 percent less than Porsche’s ceramic brake option."
More info to come on it I'm sure as the new models get tested and reviewed.
#70
If there is a Gen2 diesel buyback, I might have to get a new S. 440-HP and the 406 -TQ in a lighter, updated truck would be nice.
I'm glad they didn't make a massive change to the overall look so I don't lust for it as much. It looks good but not like a "I must have one" change.
Even the base V6 gets the 0-60 in just under 6 seconds which is nice.
#73
Ah nice, the Porsche 'dreamland'...when in reality we're just slugging it out around the beltway trying to get, say, from Colesville Rd to the American Legion Bridge in less than two hours!!
#75
