Offroad conversion for 2012 Cayenne S
The 'Otis' page is still up & running - added a build sheet - let us know if y'all have any questions!
https://rennlist.com/forums/porsche-...meet-otis.html
First two photos from the snow-ice-mud covered off-road Totem Rally between Cache Creek and 100 Mile House BC. Queued up in line for the start of a stage. Otis did get a bit dirty. Last photo from a run up to Lonesome Lake which is near Mt Rainier, WA. Prepping 'Otis' for the February Thunderbird Rally in Merritt, BC.
Do you have any images you would share of the undercarriage? I am interested how you've reinforced the underside, where you've tied in, etc. I assume you had custom bits made. Thanks!
Yes I will post photos of the skid plates, just need to get time to find them with the holiday. Will PM you when they are up on 'Meet Otis'. Yes everything is custom made or modified. If you get PCA's Pano there is a small photo of the plates in the December 2016 issue on page 60.
Already on the 'Meet Otis' thread there are photos of how the bush bar is attached using both front tow hook receptacles. The park assist sensors are integrated into the bush bar. The rear tire rack is mainly supported by the trailer hitch receiver with stabilization from the two rear tow hook receptacles.
____________________________
https://rennlist.com/forums/porsche-...et-otis-4.html
BC 99 is a road all should have the opportunity to take one day.
Thanks Richard - I just checked out the panorama image and would like to see pics of the front skid plate and its bumper mounting and underside attachments. So you haven't had a need to have any rocker protection, as I see you have the standard plastic covers on there still? Also I see you don't run the factory plastic stone guards in the rear suspension frame and a-arms. Also, if you don't mind elaborating, how is the front bush bar actually threaded/attached into the front tow hook mounts since I don't see a mount bolt on the face? Very slick design, especially those park assist sensors!!
Best would be if admin's would put another group at the same level as Cayenne 958 - 2011 --> for 'Off-Road & Overland Cayennes'
Especially as all models are out exploring roads less taken, coloring outside the yellow & white lines!
I kept the 255/55-20 Bridgestone Blizzak tires I had from my old truck, so I found some 20" Cayenne wheels to mount them on for a trip to Colorado over the holidays.
They're 31" diameter and just clear at the front of the front fender well.
Unfortunately I never found snow to play in on this trip. The tires worked fine though although I kept my speed and cornering to much lower levels than I would with the Michelin Pilots.
I'm also glad to see others have kept their orange side markers...clears are so overrated!
TXCOMT
I know this is old stuff. I own a Cayenne Diesel 2013 and just got compensation for the diesel cheat. I have been thinking of trading it in for a while now but am thinking why not use the compensation to upgrade my Cayenne to more off-road capable machine. It wont fetch much to sell it and what can I replace it with ? So I am going to keep it.
Can you fit 18" wheels over the brake disks so you can run proper off-road tires?
I had the diesel recall done recently and yes there is a noticeable change in behaviour. During very slow speed with light pressure on your accelerator, it's jerky with huge delay in response. You will automatically put more pressure to your accelerator then a sudden surge of power. Take some practice to master. If you engage the sports mode, then its back to normal i.e. same as before the recall fix. I am using the original 18". Thinking of slight lift and more offroad style tires thats still comfortable on road. A roof rack. (Might have problem because of moon roof).
I have the spaccer lift and can't find a place to get it installed. My usual shop says that installing the spacer lift will eliminate any suspension travel. I know they are wrong.
Then it follows that the extra performance sport mode used to give before the recall 'fix' no longer exists.
Glad we have decided to not get the 'fix' for our diesel.
Issue we have with getting larger diameter tires for our 2013 diesel are the inter-coolers for the diesel turbos. Much beyond a 29" diameter would impinge them especially in off-road technical situations. Our air suspension on high would mitigate this however it automatically lowers when going not much over a crawl speed. With the suspension lowered, tire impingement on the inter-coolers would be an issue for us. All this said we have done six years & 80k miles principally as off-road travel with our 255/55/18 Grabber AT2s - will be swapping to KO2s for next season.
https://rennlist.com/forums/cayenne-...meet-otis.html
