Better cup holders for 958 Cayenne?
#46
Tom,
I’m interested in a pair of the inserts. Please send the price to mrdowns@comcast.net
Thanks,
Mike
Thanks,
Mike
#49
I bought the two Porsche cup holder inserts. I couldn’t stand the tall one, too big. I don’t drink big gulps. I just wanted my coffee mug not to tip over. I ended up cutting the taller cup holder just below where it flares out at the top. Works great. Doesn’t get in the way. The near cup holder in the picture shows the large Porsche one that’s been trimmed. The far side is the soda can Porsche cup holder.
#50
Yeah I had a very bad incident the first time I let a friend drive the car. I designed mine to fit a Yeti as that is the most common beverage holder in my house. Two fit side by side no problems. The only issue, if you call it that, is that you need to give the Yeti a twist when you pull it out or it will bring the holder with it sometimes. I may try printing them a little thinner and adding a bump or two in there to reduce their grip. We'll see. I print mine out of ABS, BTW.
#52
I couldn't see paying $60 for the Tequipment version so I created these from scratch. This should be a pretty close approximation though the top may not be quite as wide. It does hold the larger plastic cups the fast food places use.
For those with 3D printers the STL file may be found here: http://www.thingiverse.com/thing:2166094
Great job! Mind sharing version 7? I see you have version 2 shared which I'll test in the morning but I'm sure version 7 must be better
#53
I like to get two cup holder from you. How can I order? Can you email me? us_matrix@yahoo.com
#54
If anyone is interested I finalized the 7th iteration of the design and printed up a few using PETG filament, which should survive during the Summer months. I did the originals using PLA which would have worked fine until the interiors started to warm up significantly. This version works with a low profile USB charger in the socket with two cup holders in place.
If you would like more details or would like 1 or 2 drop me a PM.
The website wont let me PM you, can you email me at Josh.custompcs@yahoo.com? Im interested in these thank you
#55
2017 Cayenne cup holder extension
Tom,
Thanks,
Mike
Thanks,
Mike
#56
I've thought about putting some double sided tape in there to hold the extender in place but haven't gotten to it yet.
Nice work in this thread though!
#57
#58
I just keep a cycling water bottle in the driver's door pocket.
If I need more complicated beverage service than that, I'll hire a guy to sit in the back, mix smoothies and hand them up as I need.
