Reverse Camera
How about pearl auto.
https://pearlauto.com/
Its not OEM, but there is no hard wiring. Just take it off if you have to take it in for service.
The V8 Porschephile
The wiring harness on your Cayenne is VIN specific. This means that the harness was built for your car and for the accompanying options. Because of this, it is practically impossible to retrofit an OEM rear camera on your car. Aside from the huge parts cost, required disassembly of the rear hatch roof cover, hacking into the existing harness and subsequent dealer programming, your chances are very slim of having a functional camera at the end of the day. I've looked into doing this mod in detail several years ago, and the cost and time to do so didn't make any sense at all.
NAV-TV sells a module and camera system that apparently works with the PCM 3.1. I haven't tried them out but have their info here: https://navtv.com/products/NTV-KIT375/pcm31-xg-cam.html
