Sponsored By:
Sponsored By:
Cayenne S 958 - ATF Fluid change
Old Aug 24, 2017 | 12:14 AM
  #31
garrett376's Avatar
garrett376
What's the need to keep dividing up the forums? I think it makes it far less useful when searching for things across 3 different forums.
Old Aug 24, 2017 | 05:10 AM
  #32
Ghost Ryder's Avatar
Ghost Ryder
Do S and turbo use the same fluid?
Old Aug 24, 2017 | 09:15 AM
  #33
r553's Avatar
r553
Be careful handling #2 "drain plug tube". It has to come from Germany if you need one.
Old Aug 24, 2017 | 11:01 AM
  #34
garrett376's Avatar
garrett376
It's a pretty robust little part, but I have a spare if anyone needs one.
Old Aug 24, 2017 | 02:03 PM
  #35
chiapet15's Avatar
chiapet15
Would this be the correct transmission fluid, filter, and gasket kit to purchase for the ATF change?
https://www.blauparts.com/proddetail.asp?prod=F2A1044-C
Seems to have the correct part number for the fluid and claims to fit all models of 958
Old Aug 24, 2017 | 07:25 PM
  #36
deilenberger's Avatar
deilenberger
It isn't being "divided" - the thread would be COPIED to the DIY forum, and continue to also exist here. If anything - that should make it easier to find.
And your post and this reply post are two that will have to be removed if this ever is to become a DIY. Just sayin..
Old Aug 24, 2017 | 07:26 PM
  #37
deilenberger
According to on-line Porsche dealer parts catalogs - yes. As do ALL 958 Cayenne automatics.
Old Aug 24, 2017 | 07:49 PM
  #38
deilenberger
There is a "new" thread in the DIY forum - in collaboration with "r553" - this thread has been condensed a bit to remove extraneous or unneeded postings and copied into a new stickied thread.
The DIY can be found at: https://rennlist.com/forums/cayenne-...nt-thread.html
Comments on it should be directed to me via PM.
Thanks for your cooperation.
Old Aug 29, 2017 | 02:09 PM
  #39
r553's Avatar
r553
Here is the label from the Ravenol T-WS ATF fluid for 8 speed Aisin transmissions
Old Aug 29, 2017 | 04:39 PM
  #40
deilenberger
Thanks to R553 - the ATF thread in the DIY forum now has a chart listing some compatible transmission oils.
It can be seen at: https://rennlist.com/forums/cayenne-...atf-fluid.html
The Ravenol doesn't specifically list the Cayenne on the label, but if you go to the Revenol website and use their tool to search for compatible fluids - the T-WS Lifetime fluid is spec'd for the Cayenne 8 speed transmission.
Old Sep 15, 2017 | 06:47 PM
  #41
r553's Avatar
r553
I received the ATF gaskets, filter, fill tube and o-rings today from Sonnen. The filter is Japanese Roki co brand with a P/N of PA66 - GF33.
Here are photos of the parts.
ATF Filter with Porsche PN
ATF Filter Manufacturers PN
Pan Gasket
ATF filter o-ring, drain plug and drain plug gasket
Oil tube ( bought as a spare )
Last edited by r553; Sep 25, 2017 at 08:24 PM. Reason: deleted NAPA filter P/N, fixed English
Old Sep 25, 2017 | 01:13 PM
  #42
deilenberger
Thumbs up
Thanks again to Rob! The enlightening photos and text have been copied to the DIY thread: https://rennlist.com/forums/cayenne-...atf-fluid.html
Old Mar 9, 2018 | 03:19 AM
  #43
chiapet15's Avatar
chiapet15
How would I remove this plastic cover that's underneath the radiator area? This is the cover that's in front of the one that's removed for engine oil and differential fluid changes. The goal is to remove this to gain access to the transmission cooler so I can drain the fluid out of the lines and cooler, per alldatadiy instructions; unfortunately, the manual doesn't go over how to remove that bottom cover
Old Jun 19, 2018 | 11:47 AM
  #44
Tom M's Avatar
Tom M
I'm getting ready to do the ATF fluid/filter change on my CS w/103K on it in a few weeks. In searching around I ran across this DIY over on the VWVortex forum which has quite a bit of information which also applies here as it's also got the fill tube which needs to be removed and temps monitored while setting the correct level.
http://forums.vwvortex.com/showthrea...1#post84962960
Old Jun 21, 2018 | 03:15 PM
  #45
assyrianme's Avatar
assyrianme
Hello. I keep reading about instructions for changing the trans fluid and calling it a flush. Any idea how to get the oil out of the torque converter? The cooler line method?
