Transfer case fluid fill amount
Today, I tried to change transfer case fluid on my 2014 C GTS and about .875 liters came out. The transfer case fluid kit I bought from fcpeuro came with Porsche original tc fluid which is .85 liters. When I filled the transfer case nothing came out of the fill hole.
All DIY videos I watched show people filling tc until fluid starts coming out of the fill hole. I’m kind of confused now and under impression that I didn’t put enough fluid. My research shows my vehicle takes .78 liters of tc fluid. What’s going on? Should I buy another container and fill until fluid starts coming out of the fill hole, or I’m good?
Per Porsche, "0.92 quarts (0.875 liter)"
If nothing came out during the fill, then there is a bit of a forward lean on the car. The transfer case has the prescribed amount in it. All is well.
JUST DON'T crack the case over tightening the fill/drain plugs.
It's 100% fine. You likely didn't drain every drop out either. Nothing to flush, just change fluid every other engine oil change.
.025 liters is less than 2 tablespoons.
Again, all is well.
Regarding the drain and fill plugs: https://rennlist.com/forums/diy-caye...-change-2.html go to post 24 for my method of avoiding cracking the case.
Again, all is well.
Again, all is well.
Again, all is well.
