Sponsored By:
Sponsored By:
ECU Connector Diss-assembly, anyone?
Old May 16, 2024 | 02:07 PM
16vsilverstreak's Avatar
16vsilverstreak
Default ECU Connector Diss-assembly, anyone?
Any tips and tricks to dissassemble this ECU connector? Purple slider out. Keep running into dead ends.
Old May 16, 2024 | 10:29 PM
garrett376's Avatar
garrett376
Which de-pinning tool did you try?
Old May 16, 2024 | 10:31 PM
16vsilverstreak
I’m currently trying to procure a release tool small enough.
Old May 17, 2024 | 06:27 PM
Hayabusa3's Avatar
Hayabusa3
You'll absolutely need the correct pin removal tool - you'll almost certainly destroy the very fragile wire terminal ends using a cheap generic pin out tool.. With that in hand, you'll need to push the wire slightly back into the connector while inserting the release tool through the front.... wiggle and attempt to pull the wire out. Failing that, it'll be a case of holding your tongue just right.....
