diesel valve cover grommet leaks.
I have a Cayenne diesel 2014 with 111,000 miles. Injectors failed in one, three, and then finally two. After changing the injector the rubber grommets for the injector the bolt, as well as for the pivot pin are weeping. What a pain in the ****.
I can’t get the dealer to tell me if I can buy these separate or if they come on a new valve cover.
Has anyone replaced the valve cover on the diesel and did it come with the rubber grommets already installed?
I can’t even find these for sale,
I understand it needs a new valve cover gasket.
Any leads would be appreciated.
I think what you need for the small grommets (bolt and pin) are the following: 059 103 631 D
The larger grommet that goes where the injector is inserted is part number: 059 103 085 L
These are VW part numbers, not sure what the Porsche part numbers would be.
AbominableR (02-01-2024)
