PIWIS II help with KESSY antenna debugging
Hey all, searched quite a bit but could not find what I needed. KESSY is not working for me suddenly, "key not recognized" when using the dummy key. Changed battery in FOB, locked unlocked with physical key in the door, then started and FOB unlock, etc etc and did all the other tricks mentioned on here with no luck. I have a working PIWIS II that I've done a few things with but am at a loss on how to debug the antennas for the KESSY. Is that possible with the PIWIS II? I do not see "KESSY" Control Unit in my software but I've seen screenshots on here with that listed as a selectable control unit.
Does anyone know how to debug KESSY with PIWIS II? Any help or insight would be helpful.
hey there, thanks for the reply. I've seen your posts which lead me to check the inputs from the doors; the locks do not appear to be sending constant signals - checked this in my first screenshot in post #2. But honestly, I'm not even sure if that is where it would appear or not.
It's a short in the handle itself, which causes the circuit to close and the car to believe someone is pressing the button. It then looks for the key next to the handle and, not sensing it (because the key is inside the car), it alerts you that it doesn't recognize it.
I've now dealt with this issue in 4-5 handles. I would be willing to bet your issue is in the handle.
reissgrant (02-01-2024)
