958.1 PDLS Coding
Recently ran into an issue after an error in coding my 2013. I accidentally chose 'Online Coding' on my Launch reader under the front-end electronic module. That resulted in me having to reprogram the configuration and options of my 2013 CD. One error I'm still having is the coding of my right and left headlights. It's causing a headlight fault control in my cluster and the headlights will not accept coding. I keep getting an error of 'PID:0600' when it attempts to code. I'm assuming I don't have a configuration properly set in the front end electronics on my specific headlight options, static cornering lights, etc. I will note that the headlights still work and turn on, I just get the headlight fault.
Anyone have any recommendations? Or if anyone has a Launch and 958.1 with PDLS, would they mind sharing which options should be configured as active?
