958.1 base VR6 PCV "external" conversion
Quick update....I've put 30k+ miles so far on the external PCV....only change i've made is that a catch can was added 9-10k? miles ago.
I see that someone posted above that the dayco hose collapsing. It's been averaging 90 degrees where I'm at and I've redlined 1-3rd gears without any issues. I've repeated this many times over the past month without any issue. I wonder if this is a 957 issues? as the person posted has a 08. My 2012/958.1 does not have this issue.
Both of mine made different noises that could be traced to the back of the engine but it was tough to pinpoint. Covering the hole and having it go away was key to diagnosing. My 2009 was throwing codes, the 2016 I only heard so possibly caught it early.
I did the aftermarket PCV repair rkxtexh.com on my 2009. 2016 was covered by CPO so new valve cover. The external fix should stop the noise as that is basically a whistle or harmonic sound due to air pass through that shouldn't.
Mark
Mark
I Ordered the parts and they should be arriving over weekend. will be converting our 2014 with 105K miles. Any info on your catch can addition?
I'll grab a picture later but catch can is a amazon $21 one
Aluminum Alloy Oil Catch Can Reservior 300ml Automotive Replacement Catch Can Breather Tank.
Success story!
Job was relatively easy to do, the "squeak" noise is now gone! The only thing that worries me is the "durability" or flexibility of the Dayco hose. I've driven the car a bit after doing the conversion and the Dayo hose looks difference (like vacuumed)
May this cause any issues or mess up the oxygen/oil mixture back to the engine? Attached pics
Final Result
Before driving / engine off
After Driving / engine on
Final Result
Thanks again for the write up! I never would have even thought to convert to the external PCV. You saved me a bunch of time and aggravation
I did add the 1/2" metal tube to the inside of the Dayco hose , as mentioned by another member to prevent the hose from collapsing.
Idle has returned to normal and i cleared the engine codes and they have not returned.
if i may ask, which metal pipe did you install and how?
I used a 1/2" aluminum tube that i had. I cut a small piece and a large piece to fill in the straight sections. I just used motor oil on the inside of hose and pretty much pressed the tube in. The 1/2 galvanized conduit mentioned by bartekgombos is pretty cheap from lowes or home depot. I think around $6 and seems like a good option to stiffen the hose. Just have to make sure it doesn't collapse at the bend
