Clock spring removal
I've searched this and other forums, but couldn't find the information that would help me remove the slip ring for repair outlined below. Don't want to break any tabs, but I didn't get past the removal of the steering wheel.
Thanks.
Slip ring repair - https://rennlist.com/forums/cayenne-...wn-w-pics.html
Thanks.
Maybe check 911 thread of same year: 991 and 992?
Hopefully a step by step tutorial is available.
Google and youtube search.
Hopefully your search will educate you enough to tackle the Cayenne steering wheel/clock spring.
For what its worth, I have never heard of a RennLister fixing a part on the Cayenne steering wheel.
Good luck.
Good luck.
I thought I took pics when I replaced mine (not repaired). Regardless, I think there are 1-2? screws once the steering wheel is off. Two plugs at the bottom need to be unplugged.
Here's the clock spring itself, it detaches from the turn signals. https://www.ebay.com/p/12023141834
