Sponsored By:
Sponsored By:
Compass Option
Old 03-10-2023, 10:06 PM
SSDVC
SSDVC's Avatar
Default Compass Option
Has anyone ever Seen this option (picture 86). Anyone know if this can be retrofitted and what the part number is?
Old 03-10-2023, 10:25 PM
F SANE IL
F SANE IL's Avatar
There's no pic
Old 03-11-2023, 12:31 PM
SSDVC
SSDVC's Avatar
Sorry about that. Lots of stuff going on at one time and threw some whiskey on top of it !! Again, picture #86.
​​​​​​https://bringatrailer.com/listing/20...enne-diesel-9/
Old 03-11-2023, 01:05 PM
GTS_Jay
GTS_Jay's Avatar
Here to make it easier for everyone. I saw this the other day on B.A.T. and I like it.
Old 03-11-2023, 02:28 PM
SSDVC
SSDVC's Avatar
I think the option code is 7T0, but not sure.
Old 03-11-2023, 03:43 PM
ShdwFx
ShdwFx's Avatar
I've got the Compass option on my '11 S and it's listed as option code QR1 per VIN Analytics for $420. I would think you could retrofit but would require some coding to be done afterwards.
Old 03-11-2023, 05:09 PM
F SANE IL
F SANE IL's Avatar
Yes, you can get this. There are threads on here about it. You must purchase the panel, the clock and a wire. Then cut into some wires in the back of the radio
Old 03-12-2023, 07:43 PM
SSDVC
SSDVC's Avatar
​​​​​​So not a plug and play upgrade? Bummer, as I am not up for hacking up anything in the dash.
Old 03-13-2023, 08:07 AM
PhineasFlynn
PhineasFlynn's Avatar
If you already have a clock in that spot, it is plug and play. I changed mine to the compass from the clock. No changes needed other than taking out the clock and replace with compass. I found the compass off eBay.
Old 03-13-2023, 09:50 AM
ChrisTDI
ChrisTDI's Avatar
Same dash panel as well?
Old 03-13-2023, 10:03 AM
PhineasFlynn
Yes, if you have the clock already like above picture. Just remove clock and plug in compass. At least it worked on my 2014 CTT and friend's 2013 GTS.
Old 03-13-2023, 10:17 AM
F SANE IL
F SANE IL's Avatar
This is 100% correct.
The panel, clock and wire only needed if your current panel is flat.
Old 03-13-2023, 10:19 AM
F SANE IL
F SANE IL's Avatar
Yes, it's same panel, just different Guage basically.
Old 03-13-2023, 09:56 PM
Mtea
Mtea's Avatar
I’m a fan of the old clocks and like mine where it is on the dash. I don’t really see the need for the compass there as you can select a compass to show in your in-dash PCM display on the vehicle screen I think. I have mine up all the time. The CDs are becoming hot items on BAT aren’t they.
Old 03-13-2023, 10:24 PM
garrett376
garrett376's Avatar
I like the compass most for its elevation indication.
