Replacing Valve cover gasket, should I do VVT?
https://rennlist.com/forums/diy-caye...-actuator.html
2, 1 per head...and apparently 2 (1 per) in the back as well. Ive got 114k on the turbo, should i do these now?
Changing gaskets because i've got a leak somewhere and im guessing its either the gasket or brake booster in the back.
Reason i ask is because its 325+ per actuator.
