Sponsored By:
Sponsored By:
Key not recognized
Old Nov 18, 2022 | 09:29 PM
Toreador's Avatar
Toreador
Menace to Society
Default Key not recognized
Key that used to work fine is now "Not Recognized"
is there something I can do it is this a dealer only thing?
Thankfully the second key works fine
Old Nov 18, 2022 | 10:28 PM
leftlane's Avatar
leftlane
Mine does this occasionally, usually when it is in close proximity to my phone. Is it doing it all the time? Did you try a new battery?
Old Nov 18, 2022 | 11:55 PM
Toreador's Avatar
Toreador
Menace to Society
Yep, new battery in. Phone nowhere close
Old Nov 19, 2022 | 12:20 PM
reneeweiss's Avatar
reneeweiss
Mine did that too and a new battery did not change it. I suspect that perhaps the contacts for the battery may need to be cleaned. Someone also thought the fobs just wear out over time. I have a second one that was never used and the message came on to change the battery which I did and it works fine.
Old Nov 19, 2022 | 01:34 PM
TonyVan's Avatar
TonyVan
Happens to me every once in a while. I found that if I lock and unlock the car, using the key fob, it works. This while in the car.
hope it helps in your case.
Tony
Old Nov 19, 2022 | 05:03 PM
reneeweiss's Avatar
reneeweiss
When mine completely failed and my cell phone was locked in the car I tried it a few times then shook it a bit and it worked, that's why I think the contacts for the battery might have been dirty. When I changed the battery I noticed the battery that was in the fob was the same brand as I was putting in, I think maybe the dealer or independent may have changed the battery without telling me. I should go back in and clean the contacts. It is nice to have a new non scratched up fob though. I checked the voltage on the battery that was in the fob that didn't work it it showed 3 v, while the one that gave me the message on the dash to change the battery was only 2.7v and it still worked but I put in a new one anyway.
Old Jan 18, 2023 | 08:16 PM
ahimanic's Avatar
ahimanic
"Key not recognized" + KESSY problems - Rennlist - Porsche Discussion Forums
