Sponsored By:
Sponsored By:
Which tow plug adapter?
Old Nov 12, 2022 | 05:54 PM
wkearney99's Avatar
wkearney99
Default Which tow plug adapter?
My '17 GTS has the towing hitch and harness but does not have socket fixed to the underside. There's a blank plate with the 7-pin harness connector on it.
I got a Hopkins 40950 thinking it would fit... but the mounting holes through it do not line up with those in my GTS. https://hopkinstowingsolutions.com/p...fic/40950.html
Anyone know of a similar item that'll line up with the mounting holes already in the bracket? I could, of course, just drill new holes, but figure it's worth checking for a properly fitting item first.
It'd be nice to have a dual 7 and 4 pin arrangement like the Hopkins, but I could always use an in-line adapter (and I'd welcome suggestions on ones known to work). I'm aware of possible LED lamp issues with trailers, so advice on adapters geared toward those would also be helpful.
Old Nov 12, 2022 | 08:13 PM
ShdwFx's Avatar
ShdwFx
This thread may help.
Towing hitch plug
Old Nov 13, 2022 | 03:33 PM
wkearney99's Avatar
wkearney99
Towing hitch plug
Yes, that's on the right path, thanks!
