Help! Brake Booster Replacement
I recommend a subscription to either AllDataDIY or Mitchells. what year and model is your C?
I've not done the job, but you will be removing the windshield wiper assembly, removing brake lines from the master cylinder, removing the master cylinder, unscrewing a couple of bolts in the driver's foot well, release the brake pedal connection with a VW special tool and replace a specific seal.
