moon roof rattle covered by CPO?
Hey guys,
I bought a 2016 Cayenne under CPO.. I am hearing 'rattling' from the moon roof area.. is this covered under CPO?
have you checked its function / open/closed? does it rattle then?
when is the last time you confirmed the internal area was cleaned?
(& more importantly when is the last time you confirmed your cowl drains where cleaned? (behind the tires, it drains the moonroof / sunroof run off, check into that separately. Dealerships "should" do this as part of their oil change service.)
that said, if these sunroof rails are clean, I believe this is the lubricant that is recommended for use on the rails. Maybe someone else can confirm?
HHS-K hinge lubricant aerosol can 500 mL
https://www.wurthusa.com/Chemical-Pr...L/p/0893106050
it should be covered but .maybe do a few checks first?
Thx guys.. ill bring her in when I get some free time.. it rattles even when the pan roof is closed.. and typically when you gov over a bumpy road
