958 GTS Pedal Commander
I have only one complaint about my 958.1 GTS: the throttle lag when not in sport mode. Makes me crazy. In researching a solution, the Pedal Commander seems to fix this annoyance. Many of the Macan owners swear by them. Im hesitant installing this device given the lack of data for our Cayennes / cause and effect - short and long term, if any. I dont want to drive around full time in sport mode given the loudness of the secondary cat delete. Does anyone of any experience with the Pedal Commander? Or may know of a better (factory if it exists) solution?
Thanks to all!
Thanks to all!
Having owned just a few Cayennes, the lag has always been an annoyance. My Turbo S made up for it in brute force whereas the GTS needs to "think" before responding. I agree with you on the S4 as well.
Thanks to all!
Thanks to all!
For my 2016 S, I currently use a similar product "Sprint Booster" and it also does improve the throttle response. Set to Sport Mode 6. Does it solve all, no but it improves the "lag" in my opinion.
Installation is simple and can be remove just as easily if needed. I went with the Sprint Booster due to the size of the control unit (small).
Here is a link for a discount (I have not used it) listed in the classified section.
Sprint Booster Rennlist only Discount Code!! - Rennlist - Porsche Discussion Forums
Link discussing the Sprint Booster.
Anyone using Sprint booster or Pedal Commander? Feedback Appreciated - Rennlist - Porsche Discussion Forums
Racechip makes a similar product and I believe Remus may offer one as well, you will have to check actual application to your model.
Thanks Zerospeed for your feedback and suggestion. My comfort with a throttle device is higher with the Sprint Booster, moreso than the Pedal Commander. I am inching closer to buying one to solve that pesky lag problem. I am going to check out if Racechip has known success / failure stories as well.
have been thinking about one of these as well for the ole CTT, the acceleration lag in normal mode is absolutely brutal. Does it impact the throttle response in reverse too or only in drive?
Have you tried the throttle reset procedure?
turn ignition in for 60s
turn ignition off for 5s
turn ignition on 15s
turn ignition off
search for Bao Do post on Porsche Cayenne Owners club FB group for more discussion as to the difference some have experienced. I noticed an improvement in my 958.1 S.
cheers,
Tim
turn ignition off
cheers,
Tim
Bao Do is the one who started me down this journey of looking at these devices. I will try the On/Off procedure too. Thanks for sharing it.
Tim Matar (06-10-2021)
I finally installed the Sprint Booster. Very easy to install. It absolutely made an improvement in gas pedal responsiveness. Porsche definitely has the pedal on conservative side by comparison. On the SprintBooster you can change the response settings from 1-9. I’m debating between 3 and 4. I find 3 is a happy balance for most daily driving. I really like this little mod... probably way overdue. Very usable.
The following 2 users liked this post by jamiepstewart:
aforestoftrees (12-20-2021),
jpru2001 (08-28-2021)
