I'm starting g a thread to list clips that we all need once in a while. Since it's hard to decipher what clips are what in the PET catalog, I've decided to start this thread. Who knows if it will grow but here's the start.
This clip is attached to the interior door panel. They slide into the panel which allows the panel to clip to the sub panel of the door.
This clip is attached to the door sub panel. It's a 90 degree turn clip that secures the door sub panel to the interior of the metal door.
A lot of these items are shared between Porsche, VW, and Audi so there are often many options for cross-usage. I have purchased a bunch of them from Aliexpress... If I can find good links or reference numbers I'll add them to this thread.
I got a couple to contribute. These are the engine splash shield buttons. #WHT-004-750.
And for you guys that have PDCC that change your own oil. These are the little rubber isolators that hold the PDCC hose bracket to the engine block. There are actually three of them but we only mess with two of them. I keep a few spares because if you haven't broken one yet, you will. #955 343 638 10.
