Cayenne Steering stiffened through water
Hi,
I have a 2011 Cayenne diesel 3.0.
Having some issues with my steering. Whenever driving through standing water or flooding, the steering suddenly becomes stiff as if power steering malfunction but immediately comes back to normal once the flooded area gone pass.
This is not deep flood - no more than one foot deep or kerb height.
Especially when the water gets flooded around corners and as you turn the steering wheel it just stiffened. It seems like there were slight loss of engine power but I'm not sure, but that probably the feel due to the steering losing its power.
It's temporary for about 2 or 3 seconds as you drive through the flooded areas.
Any ideas what could be the fault?
Thank you for your feedback
Munawirmmg (11-19-2020)
Received 1,150 Likes
Indeed. Had an '87 535i that would do this at every puddle - pump was right at the bottom of the engine compartment with no splash shielding.
Is your underbelly pan missing or damaged? I've gone through some deep crossings with my '11 CTT and never had this happen (perhaps 12-14" deep).. Might also be a sign you're due for a new belt and tensioner.
BTW - welcome to the forum.
I was wondering if this is intended behavior. The car has acoustic sensors in the wheel wells that tell the car it is going through water. Maybe the steering stiffens up to prevent you from over correcting?
It's from an old belt, or old tensioner, or prolonged periods submerged so the belt slips. This behavior is known, as it's even mentioned in the 957 Cayenne Owners Manual in the Off-Road Driving section.
The following 3 users liked this post by garrett376:
