Diesel Exhaust Fluid (DEF) - BlueDEF PLATINUM ?
Didn't I read awhile ago that the best way is to buy a def bottle from an Audi or VW dealer? Once finished, cut the top off and use it as a funnel for future cheaper def since it locks perfectly with the hole in the CD
nathan1 (11-06-2020)
How do you know when it is full?
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Thanks, I found a place near me that had it and the nozzle (smaller than a fuel nozzle) just barely fit in the fill hole. This was at a fuel distributor, too, that sells bulk diesel, untaxed dyed diesel, etc and has some of the wider nozzle, high flow diesel pumps.
I just took the spare out and watched the pump until I hit the 4gal mark, then slowed down. I only put in 4.5 gal (think I read the capacity is 5.5gal?) and didn't fill completely because I didn't want it to overflow. FWIW, my cayenne was giving me the "will not be able to start the car in 600 miles" warning.
Cheaper and easier than buying the 2.5gal boxes, plus no packaging to waste.
skiahh (01-06-2021)
Heads up; don't let it get it too low or it may require a visit to the dealership to reset. $250
I had a situation on my '15 CD where I did not previously top off - only added 2.5gal after an oil change. At some point before the next oil change received a warning the after X miles, or would not be able to restart. I then added more to top off before reaching the end of the countdown. Unfortunately, I discovered that the warning light does not necessarily reset itself. The net result being a required to tow to the dealer despite having it full.
Does sound like a problem with the sensor or possibly the "campaign" where they replace the DEF heater element. Wonder if your dealer charged you for "fixing" the issue while also collecting the dollars from PCNA/Porsche for completing the campaign work?
Vistador’s suggestion of a used AdBlue bottle from a VW dealer or Amazon (or Porsche/BMW dealer if you like to waste $$) is the easiest and cleanest way to go. Cut the base off making the bottle into a funnel. Make a “U” shaped piece of copper tubing to slide over the vent tube so if it gurgles a bit the DEF spits back int the funnel. Keep filling until DEF tank is full and funnel stops emptying. The funnel can be unscrewed and pulled off the fill port without spilling a drop. If there is a bunch left in the funnel, just dispense the remainder back into the jug. If the $2 a gallon savings of truck stop DEF is appealing, use your homemade funnel and be assured you won’t overflow into the spare tire well.
