Sponsored By:
Sponsored By:
958 fluid leak
Old Oct 24, 2020 | 12:46 AM
johnrg's Avatar
johnrg
4th Gear
Default 958 fluid leak
So we just had our cayenne serviced for numerous reasons and numerous times. Recently we had the water pump replaced after it spilled coolant everywhere on the driveway. Now after about 5 min of driving. We go inside to grab food and 5 min later there is about 2 bottles full of fluid on the ground and it seems to be leaking from behind the front passenger wheel of the car. Any ideas
this could be. Was not oil and seemed to much for ac condensation. Thanks in advance
Old Oct 24, 2020 | 03:22 PM
RAudi Driver's Avatar
RAudi Driver
my ac can drop that much.
Old Oct 25, 2020 | 12:41 AM
Tom M's Avatar
Tom M
Window washer fluid?
Old Oct 25, 2020 | 09:55 AM
KBell's Avatar
KBell
Agree with Audi driver.
That is where the AC drips water.
Touch and smell the fluid. It will be water.
Old Oct 26, 2020 | 11:40 PM
deilenberger's Avatar
deilenberger
That's also a clue that your HVAC drain vent is at least partly plugged up. It shouldn't have had that much water in it - it should drain continuously - in this case it drained while you were inside. I'd suggest going to the DIY forum and read up on the various drain articles there. That's a fairly easy one to clean out.. (I've done it in the parking lot of a motel in about 20 minutes..)
