CD owners please chime in
2 weeks ago, I got a CEL with flashing glow plug. With icarscan I checked codes and found high pressure fuel pump code. I l’ve have asked forum if anyone had a clue but I got almost no response.
Took it to Porsche dealership near my area since I have dieselgate warranty. After 2 days of trying to diagnose the issue, they blamed what they call “aftermarket” fuel filter which I replaced 1k miles ago that I bought from Amazon (MANN filter) and want to charge me $400 something for this saying warranty does not cover this. I told them first of all I didn’t authorize to do this change. Second, there is no way a fuel filter would throw this error. I have told them many Porsche parts are made by MANN so it is NOT really aftermarket part. They are insisting that this is the problem and error code is gone (or for now at least) and I refused this solution saying this is not going to solve the problem and problem will retun next day i start the car.
Can a dealership do a change like this without asking me first knowing they wont use warranty on this? They already know the reason I am here because of warranty I have and not willing to come for service to pay if it is outside warranty.
Anyone faced similar issue? What should I do about it?
So they changed the filter as a part of the diagnosis? When you dropped it off was there a dollar amount you initialed or signed next to to authorize a diag? I assume no because it was presumed to be a warranty issue.
Perhaps have them or you drive it for a few days and see if it pops up? Did they toss your nearly new filter?
I had an issue like this with a Cadillac in the past but it was a cheaper issue and it took a lot of arguing and discussion with the Service Manager. I had to pay to pick my car up. I then explained that I was paying for something I don't agree with to get my car that was being held hostage. I was sent a refund for my charges, but it left a very sour taste in my mouth with that dealership.
As a last resort, if you don't get a resolution to your liking you can also file a complaint with the BBB regarding the dealer. The BBB in itself is pretty useless but I know from prior experience that the dealership will not like the image and it can spur further discussion.
I would ask them to show you the failed part and explain how it caused the issue. Given that it ran fine on this filter for 1000 miles it seems unlikely that is the root cause unless it is actually plugged with debris which should be easy enough to show. I'm guessing they will have conveniently thrown the filter away though.
Unfortunately you are probably going to be stuck paying something for this "fix". I'd stress that you are not happy about this outcome, that they should have called to get the Ok when it went from warranty to billing you and that now that you have an OEM filter you don't want to hear any crap if/when the CEL comes back on. I'd also stress you want to be sure you bought the correct filter and didn't screw something up (unlikely with a fuel filter change but, still) prior to raising too much hell with them.
FYI, I've been running a Mahle (not mann) filter with no problems for 15K miles.
I find this ridiculous as this is first of all not the problem and second they are blaming aftermarket part for an issue so that they don’t want to bill the warranty. I actually have
I am still going to fight that as I did not authorize this change and this problem is not the fix. Of course if they have asked me before they did the change, I would have not authorized it. I actually have the paper of my signature showing this is zero cost repair and when I dropped this to thr dealership
Worst comes to worst, I contact Porsche NA about this
Filter is not the issue and I am 100% certain of that because I had it for ~1000 miles. Plus this MANN filter is exactly the Porsche OEM filter without the Porsche Logo ( if it actually has a Porsche logo).
Unfortunately if the condition appears to be fixed by the new filter, at least for now, about the only leg you have to stand on is not authorizing them to do billable work. That said I'm guessing if they want to play hardball you'll be paying something (maybe not the full amount) to get your vehicle back. Maybe you could argue towards getting some of that money back if the CEl comes back on in the near future as you could then possibly prove they did not fix the root cause of the issue. I would not expect Porsche NA to be much help in this matter but, maybe they'll send you a coffee mug or something for troubles.
Good luck getting things resolved.
I'd definitely argue hard and maybe suggest that you will pay if the CEL stays off for another 1,000 miles? I know you don't think it could have been the filter (it does seem ridiculous, I've used Mann for the last 2 I've replaced), but if the light stays off, then I guess that's good right?
As a worst case scenario, you could offer to split the $400?
Dealers are the worst. I thought buying a car with a warranty would be a good idea but I've spent far too much time and energy arguing with mine about repairs and their effort to diagnose things. I'd rather fix it myself.
I'm agreeing with you. You can read my posts and see I'm not a fan of the crap dealers pull to extract money from customers. I don't believe the filter or the installation is the issue either, hence my suggestion of asking them to show you the defective part and explain how they determined this part caused the problem. I'm guessing they just assumed the filter had not been changed and it was the easiest place to start. I also guessing they will not be able to produce this part which helps your argument. Basically building towards "So you can't show me the problem. I just need to trust you and pay your extortionate labor rate for what shouldn't be more than a $50 part and less than an hour of shop time."
Didn't want to start new thread. I also have an issue with dealer now. Car is throwing DPF code and it needs to be replaced. They reset my ECU and told me to pick up the car, saying that Porsche does not authorize DPF replacements unless code comes back again. I've never heard any of any dealer reseting codes and sending customers home before. And on top of this, this is the 3rd time DPF code comes up, but they still want it to come back for the 4th time now.
Sounds like a solid lawsuit where VW is trying to save a few bucks by not honoring dieselgate warranty.
There is something fishy.....dealership is making up stories like some small crappy used car dealer. I contacted Porsche to see what they say. Car is sitting on the lot for 2 days now....I am waiting for answers. So far none of this makes any sense to me.
Edit: what a crown show. Porsche of America just refuses to call me while dealership is saying they already spoke with PoA and they can't do anything to help me. Every time i call Porsche, rep thats on the case is busy for entire week now and doesn't pick up the phone. ****ing pathetic
Now this will make me think twice before dropping it to the dealership if another CEL comes again.
