2011 Cayenne Turbo engine noise
I bought a used 2011 Cayenne Turbo with around 20,000 miles, everything was fine when I bought the car. Today I noticed that the engine was really noisy. No check engine, no errors.
Could it be scored cylinders even with very low mileage?
Thanks guys.
Thanks guys.
20k miles on a 2011 car in 2020!? I'm surprised.... Did you buy from private seller or some dealer? maybe take it back? Did you check oil? Did you check if cam bolts been replaced already? Don't kill it, good luck.
Bought it from a private seller. Where I live, people dont daily drive these kinds of vehicles, hence the low mileage. Checked the cam bolts and they are not yet replaced. Just checked the bolts yeaterday and was already planning on having it replaced then this happened. Could it be related to the bolts?
Just tried to check to oil level and just learned that there is no dipstick. Checked using the gauge but it says display only after a short time/distance. Although I never got a warning of low oil while I drove it a few days ago. I guess I’ll have to start it up and drive it for a few minutes for the gauge to show the oil level, is that ok? I’m worried about causing more damage if I start the engine.
I don't believe that scored cylinders really make any noise. I always associated scoring with consuming oil being the primary sympton. I'm not sure what that would be though. Its possible its a cam bolt, or something similar, since from the sound it appears like it would be on the top end or valve related. It could be something as simple as belt tensioner, but its hard to tell. I would suggest having it towed to a mechanic
I stupidly started the engine to move the car to a better spot for easy access to diagnose and replace the cam bolts, now the engine died and threw lots of faults.
If it is, what are my next steps? From what I've gathered:
- Try to recover all bolt pieces
- Check head for damage
- leak down test
- leak down test
Received 1,150 Likes
Are the faults below due to the camshaft bolts? We don't have the recall here in our country.
- leak down test
- leak down test
Other than that - I don't know how skilled mechanically you are - but Porsche's rule is - if they can't retrieve ALL the bits of broken bolts - the engine gets replaced. Dunno how possible that is wherever you're located. If the bolt bits are found I think you're still in for a rebuild of the head on that side, which typically requires a number of special timing tools to accomplish - and possibly engine removal from the vehicle. You very likely have several bent valves.
California has a 30 day warranty on all used cars. Maybe your state does also.
