Any TC Failures with new GNC Coated Plates
My third TC was installed in my 2016 Cayenne Base in Feb/19 - with the new GNC coated plates. Since then, I have put nearly 20K miles on vehicle - the mileage when the previous two TC's started to fail. So far, my Cayenne is running well - without any TC fluid changes. Has anyone replaced a TC with the new GNC coated plates? Has this new TC case resolved the failure issue?
GNC? Is this the factory upgrade or aftermarket?
Factory replacement TC - they went into service around October 2018. There is Technical Information Service Bulletin dated September 26, 2018 stating "Only modified transfer cases with GNC-coated plates are supplied from now on".
Porsche service advisor recommended not changing fluid under warranty. Now that I am out of warranty, I will start changing fluid every other oil change.
Bassman37 (03-17-2022)
I got the new GNC case Jun 2019 but i haven't clocked the mileage yet...
This is the link to the TSB: https://static.nhtsa.gov/odi/tsbs/20...45566-9999.pdf
LU2 – Transfer gear reinforced
An interesting read on gas nitrocarburising .. https://www.linde-gaz.pl/pl/images/F...m48-461074.pdf
There another revision to clutches - came out at end of 2019 - the "diamond clutch" and just like all of half a dozen of fixes before it - supposed to be the one that doesn't break.
