While doing an oil change noticed this from underneath the car. It’s the area in front of the oil pan on the drivers side. About the same place that the oil filter is on the right hand side. Right next to the lower most pulley. Can anyone help id what this might be? Cant tell if it’s related to pdcc or maybe water pump? Nothing to speak of on the lower engine cover. Thanks!!
Thanks y’all. Will keep an eye on it. I did spray it down with engine degreaser to remove the residue and will keep an eye on it. Other than that everything looks good!
It may be a slow weeping and not bad enough to do anything about.
