2013 958 Ignition lock replacement
Does anyone know how to access the ignition switch in 958, in order to replace it with a new one? I tried bending the plastics off but nothing wants to come off.
I broke a plastic piece that holds the key inside, can't turn the ignition on without it....
Thanks @dollarlongnecks ,
do you know where can I find instructions on removing these panels? And if I need to unplug the battery before disconnecting the switch?
1. Remove dashboard inset at the bottom. → REMOVING DASHBOARD INSET - section on "Removing"
2. Remove trim panel under dashboard at the left. → REMOVING TRIM PANEL UNDER DASHBOARD - section on "Removing"
Thanks all, unfortunately there is no section for taking the panels off, but I managed to replace it myself. I pried the side panel off, unscrewed the vent and was able to pry the small ignition panel off. Then for the switch itself I was able to rotate the front cap that was holding it using a flat screwdriver, unplug it from behind and bend the bottom panels off to take it out. Didn't have to unplug the battery either.
dollarlongnecks (02-09-2020)
