clip only for a 2011-18 Cayenne Rear Black Luggage Compartment Cover ? CPO coverage?
looking to see if it is possible to source a BLACK clip / tab for a
Porsche 2011 18 Cayenne Rear Black Luggage Compartment Cover
or is the only way to source the system to acquirer this small part from new or used from a complete system?
my vehicle is under a CPO warranty, odd question but would this be covered? (it was sold with the car, not an add on)
this is the p/n
95855177306AY1
there are four holders, i just notices one of my four clips / tabs is partly snapped.
this is the p/n
95855177306AY1
The part number you posted takes me to a full cargo cover, is that what you are seeking to buy or just the snapped clip? if you want a black cargo cover, I have a practically brand new one in black sitting in my storage from my previous 2015 Cayenne GTS.
& yes that part # is for the full cargo cover.
not sure if there is a part # for just the clip?
If you are referring to the clips that attach to the back seat for the cover extension they are not available to order. Went through this a year ago when one broke. Dealer replaced entire cover under warranty. Seems like a costly replacement for an inexpensive clip.
At some point someone needs to create a file so these can be 3D printed. I am sure others over time will have this issue after their warranties is over...
update on this, to replace the clip it does require replacing the whole complete assembly
& a broken clip is not covered under Porsche CPO warranty. I sort of figured but I asked.
Mine was covered in the original 4 year warranty. Not surprise it isn’t under CPO. It is silly that the clips aren’t replaceable. It appears the rod holding them in is removable.
The current 3D printers on the market should be able handle small objects like this. Recreation of the clip tension might be the challenge...
are you interested in selling it?
4th Gear
Worth a shot
I've got a luggage cover, but none of my clips are broken...yet.
I needed some A/C vent tabs (those break WAY too easily), and these guys make replacement vent tabs. If they make those, they can probably make luggage cover clips. You might want to check with them to see if they can do it.
https://www.venttabs.com/about-us/
support@venttabs.com
It's worth a shot.
It's worth a shot.
deilenberger (11-11-2019)
Received 1,150 Likes
It's worth a shot.
It's worth a shot.
I am sure someone has the ability to scan the clip and create the file for 3D printing? I check out that rod soon & might inquire with a couple friends at a local university.
