2016 Cayenne - constant water leaks
Hello
2016 Cayenne - Pano roof
Had a water leak in the rear which ruined the sound system, covered under warranty
Now after a big rain a large leak on passenger side, opening the door and water poured out after a huge rain storm
Anyone else dealt with this?
Received 1,151 Likes
I believe if you look at the DIY forum you'll find a number of posts addressing these sort of problems. It's usually the first place to look - even before asking here: https://rennlist.com/forums/cayenne-diy-224/
https://rennlist.com/forums/cayenne-...r-is-used.html
https://rennlist.com/forums/cayenne-...vac-drain.html
https://rennlist.com/forums/cayenne-...es-videos.html
https://rennlist.com/forums/cayenne-...clean-out.html
Couldn't see ANYTHING? Are you sure you were in the DIY forum? That is about the most popular topic there.
Water poured out of where? The door opening? That would make it at least 6" deep (there is about 1.5" of foam below the carpeting) and it would have filled up the rear footwell also... that's an amazing amount of water. Would seem possible to locate that size leak by having someone hosing the outside down while you're inside looking for it.
Really? Found in the DIY forum:
I never had any issues with drains in any of my cars for past 20+ years but apparently it's some issue with Porsches....I don't know
Maybe my misunderstanding that OPs leak is related to roof drains, it's just he noted Panoramic roof
