Is this Toast or can It be fixed. Exclusive Shifter.
As title really, bought this through Ebay for a bit of a gamble not knowing if it was broken or not, after receiving it it seems that the button is stuck. Can it be released.
If it's not broken beyond repair, I would first twist the square lock in the middle of the shifter and see if that releases anything. You have to twist it to install or remove the shifter anyway so it's part of the process. I think there should also be a rod in the shaft that's actuated by depressing the button. I'd loosen that nut and then take a pair of needle nose pliers and try to gently coerce it to see if it will loosen somehow.
