958 Cargo Partition Net
Does the 958 come with a cargo partition net like the 955 did ? I'm thinking not. My 2009 Cayenne S came with this and it was very handy with critters.
Would like to confirm this. I see an accessory available which is a little different (available from suncoast and others).
thx
karl.
thx
karl.
Received 1,150 Likes
AFAIK - it was standard equipment on all 958's. Mine came with one and it wasn't listed on the build listing as an accessory. The 958 one doesn't attach to the rear seat back, it mounts across the compartment, and has a pull up net and a pull back privacy shield for stuff in the back compartment (plus a little shield that sort of attaches to the rear of the seats to close the gap between it and the seat.)
https://porscheparts.autohausofpeori...iABEgIw2PD_BwE
It's possible that I may learn something about the cargo cover here, if it can also run vertical to the roof like the one pictured but, it solid and would obscure your rearward view if it does. There are receivers for something up there in the roof liner.
I ordered my '17 GTS with the cargo rail option (which is fantastic, btw) and among the pieces that came with the vehicle was a net of some sort. I believe it's designed to clip into the receivers in the ceiling and to the seat backs. I've never attempted to use it. It was just a net, without any fancy roller tube like what appears to be shown in the picture.
I was wrong. Must have been on the '06 S/****. Just looked at it standing up in the corner of the garage. It just has the horizontal pullouts. No vertical netting. I did find one in a catalog that had some sort of vertical pullout section - but it was around $900.. and blue.
