Certified 2017 Cayenne - Thoughts?
That's a great point. Certainly, once you search nationally or even regionally; there will be better deals to be had. I am on the fence about purchasing a used car, sight unseen.
You had no concerns or issues purchasing a used vehicle without seeing it in person or test driving it?
That is so much more peace of mind than me taking a car for a test drive. As far as options go, you can run the VIN through vinanalytics.com and see the build sheet and you know what the car has and doesn't have.
Have done the same thing with 2 Audis also.
That being said, you can still work a deal regionally and get everything set up, then fly up to test drive and sign the papers at the end. In your year range/price range, you are going to be talking about a CPO vehicle anyway it sounds like, so you'll have that further peace of mind.
No, we paid $250 for a local indy mechanic who was highly recommended in the Porsche community to pick the car up, take it to his garage, and spend 2 hours going over it in much more detail than I could ever hope to do. He gave it a thorough mechanical inspection, checked fluids, did a test drive, took a florescent lamp to the paint job (and found a couple old bumps painted over)...he actually also used the car fax to call the two previous Porsche dealerships that had serviced the car (he knew people at both of them) and got details on everything that had been done to it. Also was able to help me negotiate a little better with a couple things he found.
Sounds like you found a great indy guy to help check out the car for you. It's def 250 well spent.
Found a 2015 Cayenne S locally with 30k listing at $50k. Originally MSRP was $87k
Here are the options.
BASECayenne S
1BZPorsche Active Suspension Managemement (PASM)
1NPWheel Center Caps with Colored Porsche Crest
1XGHeated Multifunction Sport Steering Wheel in Dark Walnut
2TJet Black Metallic
4A3Seat Heating (Front)
4D3Seat Ventilation (Front)
7Y1Lane Change Assist (LCA)
9VLBose® Surround Sound System
MCStandard Interior in Luxor Beige
PE5Power Seats (14-way) with Memory Package
PH9Dark Walnut Interior Package incl. Gear Selector
PJAInfotainment Package w/o HD Radio
PJCPremium Package
U0019" Cayenne Turbo Wheels
Would you go for the 2015 S, or the 2017 Platinum (Base)? Same pricing.
BASECayenne S
PJCPremium Package
I love my 2017 Cayenne S -- well except for the fact that it now has to go in for a new transfer case -- so NO they have not fixed the issue for the 2017s. It is still under warranty so it isn't going to cost me anything but it is a PITA anyway. I've had mine for a little over 2 years -- actually bought it in Feb of 2017 used with CPO - so my price point won't mean anything for you.
Other than the new TC issue it has been a great car! Not as much fun as my Cab but I still drive it way more than the Cab since it is more DD friendly.....
TC = Transfer Case issue. Its a common recurring failure on all of the Cayenne models of this generation. Yes @ days or weeks at the dealership. $4,000-ish fix but covered under CPO or an extended warranty with power train coverage.
The long term issue is that some people continually have to replace their TC. Some people have 100,000 miles+ with no problem.
There MAY be a fix = changing the TC oil annually with your regular oil change seems to have kept the problem at bay for those that have tried it. The TC oil per Porsche is lifetime, but apparently it should not be!
See the sticky at the top of the board on the transfer case issue.
Thanks. I'll research it more.
I absolutely hate having my cars at the dealership for repairs. Fortunately, our Audis had been doing pretty well over the years. Nothing more than regular maintenance.
