958.2 '18 No Power after accident
Hi, I am new to Porsche, always been a BMW guy, but got myself a 2018 Cayenne Platinum Edition from a salvage auction which I plan to rebuild. It was in a front end collision, hit in the RH headlight, driver's wheel and knee air bags deployed. I am not a newbie when it comes to these things, so none of that scares me at all. The thing that does; however, is no power in the car and seemingly no way to get to the battery, which is why I am hoping somebody can give me some ideas on what I could do next. I have zero lights anywhere, even when I connect a jumper cable to the posts under the hood. The rear wheels are locked by parking brake.
Here is what I've done/know so far:
a) Put a battery charger overnight on the under hood posts, but got nothing out of it.
b) Checked all fuses (under the hood and both sides of the dash, and a 40Amp one on the battery distributor), none are blown.
c) Removed two front bolts, but have no way getting to the rear ones.
d) Checked under the front seat, the carpet was not cut, so it tells me that the battery is there and nobody messed around with it.
e) The battery must be connected and drained while sitting at the auction because the picture that I saw did show the car mileage on the dash.
f) The key is stuck in the ignition.
My next move was going to be go buy one of those trickle chargers that plug into the cigarette lighter and see if that does anything.
Any help is greatly appreciated you guys.
Sergei
Sergei
Did you check the Pyro Fuse?
By saying that you are not a newbie when it comes to these things, you should already know what one of these looks like. The picture is of a generic pyro fuse. On almost every car made.
The pyro fuse is blown, there's no doubt about that. However it sits under the seat next to the battery and I see no way to move the seat to get to it. I feel like I caught 22 here.
The pyro fuse is located under the hood as per the diagram I posted. I could be mistaken as I've never had to deal with it but that's what the manual is stating.
If you think it's under the seat, run 12 volts to the seat to move it to get to the bolts.
I'm beginning to think you're in over your head. These are simple steps that one who is not a newbie, should know how to do. In addition, you should have all the reading material and manuals on hand if you plan on fixing the car. Chiming in on day 1 seems like you're in over your head.
Hope you're not the person who fixes these cars then flips them.
I towed the car to them to start working on it. I'll update this thread when things start moving along.
I stand corrected. The main fuse box is under that seat.
I think it is possible to get to the pyro switch without having to remove the seat. Have your mechanic try that.
I'll check my cayenne when I go to the garage.
I just looked and depending on your seat position, it will be tight.
However, Porsche has a seat removal method titled, "In Case of Faulty fore/aft/height adjustment"
I'll post up the All data sheet but in the meantime, watch this video and it will show you how it's done. You're just 2 triple square bolts away from getting at that fuse.
Information
In the case of faulty fore-and-aft or vertical adjustment, the seat can only be removed together with the seat frame. See: Overhaul\720919 Removing and Installing Front Seat Frame
Information
Looks like there are 4 bolts on the 958 but you should be able to reach them without having to move the seat.
Your Vehicle: 2011 Porsche Cayenne Turbo (92A) V8-4.8L Turbo
WM 720919 Removing and installing front seat frame
Technical values
Preliminary work
Installation position of front seat frame
Removing seat frame
Technical values
Preliminary work
- Remove carpet.
- Unscrew four fastening screws -1- on the seat frame at the driver's side and three fastening screws on the seat frame at the passenger's side.
Removing seat frame
- Remove front seat frame by pulling it upwards.
- Position the seat frame on the floor of the vehicle.
- Tighten four fastening screws -1- on the seat frame at the driver's side and three fastening screws on the seat frame at the passenger's side to -> Tightening torque: 50 Nm (37 ftlb.)+/-7.5 Nm (+/-5.5 ftlb.) .
It was my misunderstanding that you were going to rebuild the car and not a shop. Now that it's in the hands of a body shop, they should have everything they need to repair the car correctly. Good luck and I don't think the seat removal is a 1/2 day job. Looks like an hour tops.
John
Don't know what those pictures are supposed to represent, but they don't look like they're related to the seat removal.
In fact, they randomly seem to change when reloading this page. Web site errors or something here?
Vehicle » Body and Frame » Seats » Service and Repair » Overhaul » 720919 Removing and Installing Front Seat Frame
Technical values
Preliminary work
Removing seat frame
Installing seat frame
Subsequent work
Technical values
Preliminary work
- Remove carpet.
Removing seat frame
Subsequent work
