How much to replace battery?
I have my car in for service for two new tires due to a pothole hit and apparently since my auto start stop has been malfuctioning. They found a faulty ignition coil and now apparently I need a new battery from the dealer which is 1175 with tax. ... how??? CPO should fix this no because I've had it for 3 months and the battery should be new.
What is the standard cost of a battery replacement?
Edit: Update, so my dealer that I bought it from thinks that is ridiculous and is going to pick up the car and deal with it themselves. I must say they are starting to go above and beyond for me. The dealer it's at now I was forewarned about but it was where I could send it to with roadside assistance.
Originally Posted by DAVfoto
I thought they needed to be coded with PIWIS? Yea I don't plan to have my car sent back to this dealer ever again. That sounds like Ferrari battery money.
visitador (12-18-2020)
I’ve done this on my Boxster 981. Used an aftermarket AGM with same specs as OEM. I plugged in a trickle charger to car while I swapped batteries. No issues. My auto start stop now works again so I’m guessing the car was able to recognize that I had a new battery without having to program.
My dealer wanted $900 for the battery, and my indy replaced it with the exact same battery for $600. Still way too much but I wasn't going to be pulling seats out etc to do it myself, even if some say it is easy.
BTW - the battery is only covered under the original warranty, not the CPO. Mine crapped out at 51k miles and I was SOL.
Why don't you copy the serial and part number of the old battery and follow the same format for the aftermarket battery to register?
Copied from a post in the 991 forum.
"In the meantime, I found my new mechanic for all things porsche in houston. Einar's garage in Seabrook. I took my car over there just to say hi and check out the shop. The tech connected the PIWIS II and asked me what I want to put in the battery change section. I put 95 ah, AMG, old porsche battery serial and 99961109510 as the part number. Old battery had 070 in the bolded part.
my other mechanic in houston said oh don't worry about! we change batteries and we don't do anything in the car. Einar's tech said it doesn't affect the car but it affects the life of the new battery. I highly doubt porsche would add this extra step to indicate battery capacity and type for no damn reason.
I noticed my voltage came dowe to 13.3V in normal mode after cars been running for a while and up to 14.5V in sport on the highway."
Received 1,150 Likes
Premium Sponsor
https://shop.antigravitybatteries.co...tive/ag-h6-rs/
I would definitely consider an Antigravity battery for my Cayenne if it came in the right size? I love mine in the GT4, but our Cayenne battery is a Group Size H8, and I don't find that size available on the Antigravity site...
Premium Sponsor
So when we are talking Lithium Batteries we are talking the same battery pack , 40 Ah, within any size case. So the Case size doesn't really Matter for how much battery you get. My point being if you can fit the H7 Battery in the H8 area it could work easy. I am not familiar with the Battery Area on a Cheyenne. So I'll need to look and see if they are adjustable like the other Porsches.
Premium Sponsor
24Ah/1000 ca
30Ah/1200 ca
40Ah/1500 ca
Actually with these batteries you'll have no problem cranking with any of the options. The more important variable is going to be the capacity in regards to how the battery is being used, what's drawing off of it as far as the set up and how often the car is being driven.
30Ah/1200 ca
40Ah/1500 ca
