Sponsored By:
Sponsored By:
Rear door locking problem
Old Mar 17, 2019 | 04:33 PM
tranzow's Avatar
tranzow
Default Rear door locking problem
My right rear door won't lock. All other doors lock with the remote. In order to get it to lock I had to switch it over to child lock. However the child lock is a nuisance when someone is sitting in the back seat unable to unlock the door (front and rear door lock switches won't unlock it). The only way to get the door open is for the rear passenger to pull the handle, than it allows me to unlock with the remote. Anyone have this problem or have a solution?
Old Mar 17, 2019 | 08:46 PM
Tom M's Avatar
Tom M
Solution is most likely to replace the actuator. It is a DIY if you are handy but there are quite a few steps to do it. Mine was just the opposite in that it would lock but not unlock using the remote. Oddly, it worked perfectly if the door wasn't actually closed so you might try that as well. With the door open you use a screwdriver to close the latch so the electronics think the door is closed and then operate the lock/unlock cycles to see if it works. FWIW I bought my replacement (used) actuator off eBay.
Old Mar 17, 2019 | 09:16 PM
nerdtalker's Avatar
nerdtalker
Your door lock module is probably dead. I had similar and replaced my door lock module this weekend. Oddly enough it also was the passenger rear door that failed. Symptoms were no beep on lock, and no click from the actuator when lock/unlock (put your ear against the door from the outside and compare to a working door).
Not hard to DIY, only tricky steps are getting the door handle off and the sun shade actuator pole if you have the sun shade option.
Old Mar 18, 2019 | 12:29 PM
billybill's Avatar
billybill
6th Gear
I had the exact same problem. I went to the stealership to fix it. Cost about $600. I looked into doing it myself but it looked a little too difficult for me.
Old Mar 18, 2019 | 12:47 PM
Pmorritt's Avatar
Pmorritt
humm, i’m looking around for a rear door. not there????
Old May 22, 2019 | 10:04 AM
hotrod2448's Avatar
hotrod2448
I've got this going on my drivers rear door currently. Last week it wouldn't unlock, this week it won't lock, no chirp on locking and I can hear the door locks cycling when pulling away from a stop. Still under warranty so, the dealer can deal with it.
