Front lower valance dislodged
The black valance does have tabs that fit through openings in the upper part. Once you align the two and give it a push, they should snap together. Here is a picture https://www.ebay.com/itm/232995085745?ul_noapp=true
The front apron actually appears to refer to the top portion of the cover when the hood is open. The video I saw doing a bumper removal left the bottom cover in place so it's unclear if it can be removed w/o removing the bumper.
However I would guess that if you get a flashlight and look closely you'll see the tab and whether it's broken or not.
