Recommended maintence with intake manifold
User
Looking to do the e81 upgrade to my ‘12 CTT - primarily the intake manifold and diverter - however I figure that with everything off I may want to replace some things underneath. The car has 100k and I don’t know much about previous history on it - so assume it’s all original. Ive been looking at YouTube for DIY and here as well but don’t see anything specific to this other than fixing the leaking pipe. I’m thinking coolant pipe weld fix and thermostat should be on the list - anything else? Maybe the belts may be easier to access, starter?
Also looking for the oxygen sensors - anyone know or have pictures or DIY on that?
User
https://www.6speedonline.com/forums/...rkit-pics.html
essentially it’s a partial conversion to a turbo s
Moderator
Interesting thread..
Moderator
Moderator
Also curious - do you have an AllDataDIY subscription? If you're serious about DIY on a Cayenne you should. It will avoid having to ask questions like this - there will be step by step directions on this procedure.
Moderator
As far as how many serious DIY'ers there are here - have you looked at the Cayenne DIY subforum? That should answer that question for you.
User
Yes I looked at the diy, not as much for 958’s as the 955/957’s; nothing at all on oxygen sensors. I’m considering all data but i sometimes find them hard to follow and the pictures are not always clear as to what you are looking at. Thanks for the info on the tsat and pump - I’ll have to look at what’s involved with all of this. Camera is more for everyone else - something I can post up and share on YouTube and then here
EDIT: useful
https://rennlist.com/forums/cayenne-...you-think.html
https://rennlist.com/forums/cayenne-...-firewall.html (note: diesel)
https://rennlist.com/forums/cayenne-...d-adaptor.html
Looks like ill sign up for alldataDIY - only 30 bucks for 1 car for 1 year
EDIT: useful
Last edited by Slickdvl; 02-12-2019 at 01:57 PM. Reason: found diy links that are helpful
I'm not certain but I believe Porsche might have discontinued the 957 and 958 E81 kits already, although they might still be located as NOS somewhere.
