Any instructions on how to change lower oil pan gasket of 15 CS
I have 2015 Cayenne S with 54000 miles. It's v6 with dual turbo. I find out there is oil leaking from lower oil pan while I was about to do an oil change. I cannot find any info on how to change gasket or replace the lower oil pan. Porsche doesn't even have part number for the gasket. What I find out is to get the gasket we have to buy the pan which comes with a gasket as you can see the pic blew. The part number of the pan is 946-107-015-51 and it cost $140. It's impossible to change the pan because of limited space. But it's possible to change the gasket. Please let me know if anyone has any instructions, sharing experience or part number for the bolts to the lower oil. Much appreciated!
Received 1,141 Likes
I would question if the gasket can be changed without pan removal.. there have to be parts like the oil pump and oil pump pickup going down into the pan - and I can't imagine it's possible to work the gasket around those..
After remove 19 bolts from low oil pan, it should drop down in less two fingers space but it cannot be taken off the car. I think the space allows to swap the old gasket with new one. Looking at the pic, you can see a part of low oil pan with drill plug sits in. I am not sure it could be slide out. I will try when I change it. I highly doubt it. This job is tough because we can not see what's going on. It's all by feel to make sure gasket sits in the right place and tighten in the right torque spec. This is the way I am going to do it. I ordered parts today. It would be great if anyone has done this before and shares some experience.
BTW I took the photo from SteveFromMN's oil change post. I will take some my own photos.
Out of curiosity, did you find a part number for the gasket? reason I ask is that looking at the workshop manual, it looks like you use sealant, rather than a gasket. And looking at nemigaparts.com parts diagrams, it also seems to show sealant For example
23 Sealing compound
1 tube for Oil pan 50 ml. X
Part Number 000 043 300 39 $ 28.31
Don't take my word for it on the above picture and part number. All 958 model years are covered by several diagrams, so you'd need to go into nemigaparts.com yourself to align the right drawing with your twin turbo V6.
By the way, the pdf workshop manual instructions for oil pan removal cover 25 pages (pages 5757 to 5782 on mine), and none of them cover doing it in situ. They seem to assume you'll have the engine out of the car on a stand.
Regards and good luck
Gary
23 Sealing compound
Gary
