converting air suspension to coils
#46
I’d just assume buy OEM rebuilds for $500 a pop. Not sure why you’d want to downgrade to steel for that price.
#47
not speaking to the quality at all, but you can get a set of coilovers for $1250, which is roughly the cost of one air strut.
https://ceika-store.com/products/cct1m628
https://www.ecstuning.com/b-bc-racin...-kit/y-08~bcr/
#48
#49
Don't have FB. Stay away from that brain washing, virtual whitepages platform.
But thanks for the info. I'd personally just go with FCP for life time warranty. Although I'm sure I won't have the CS long enough to have to replace again.
#50
Well, I never had Facebook but had to get an account to get in touch with people who owned a certain Motorcycle that has no presence anywhere else. Old 2 Stroke Street Bikes. If you use it wisely, then it's a good resource tool.
TXCOMT (06-17-2023)
#51
Air suspensions are fantastic, especially when you want to tow on a regular basis. There is nothing exceptionally expensive or difficult to maintaining them. I once bought an absolutely mint, low mile Range Rover L322 that "needed all entirely new air suspension components," according to the local indy shop. I simply installed a new battery and cleared the errors with INPA (BMW software) and I was ready for the Paris Dakar. With air systems, it's simply a matter of scanning for errors with the proper tool, inspecting for cracks in rubber and listening for leaks with a stethoscope. My amazing luck with the L322 was preceded by a decade of swapping out other peoples' air springs and O-rings, plus the occasional external sensor. Compressors can be rebuilt for 40 quid. There is nothing to it.
#52
I'm interested in rest of the story on bikes. You buying/selling or collecting? I used to ride/race. Sold last year when prices sky rocketed.
#53
Arnott has such a coil spring conversion kit which includes EBM, but the kit is only for 955. Nothing for 957 or 958 at this time. https://www.arnottindustries.com/coi...nversion-kits/
PS--Rover air susp isn't as well/robustly designed as Porsche (specifically Porsche's has more aluminum surrounding the bag, so less likely to get micropunctures in the bag = slow leaks = compressor working harder = larger air strut/shock/bag leak = compressor death. BTDT.), which is why Rover fails more often and there are more kits for Rover air-coil conversion than there are for VAG products like Porsche, VW, Audi.
#54
On the older Rovers, an air suspension failure puts the truck at the bottom of the suspension travel, on the bump stops. You cannot drive the truck in this mode more than 15 miles an hour, on the road.
How one would drive a Rover on the bump stops out of the woods is beyond me...and it's something I thought about as I offroaded my '95 County LWB fairly regularly...
#55
Rover fail? Hmmm..
Rover fix is to add a strut/shock top spacer kit like Lucky8 sells, for running oversized tires and still being able to drive out if/when the air susp fails/sinks. My RRS has this and it works well.
Back to Cayenne's...
