Trunk/Tailgate Not Opening Properly
Hey guys - hoping someone can help me solve this problem. When I open the trunk with the key the trunk will pop open about 2 inches then beep, then if i press it again it will pop up another 2 inches or so etc. and won't open all the way in one go. I've tried resetting the tail gate height by holding the close button until it beeps and I don't think there's anything blocking the sensors. Car is a recently purchased '13 GTS if that makes a difference. I'm wondering if I'm missing something!
Received 1,150 Likes
Manually open it all the way, then press and hold the open button on your key until you hear a beep.. it needs to know the top position. That can be adjusted for clearance by moving it to where you want it to stop going up, and holding it - then pressing and holding the open button until you hear a beep.
Have tried all the above (except for the resetting from dealer) and the problem still remains. Very strange. I think the next step is takin it to the stealership to get the controller cleared
GTCharlie (05-07-2023)
