958 GTS Transfer Case rebuild - wish me luck
Glad someone else on here tackled this since my plans to do so where ceased by getting rid of mine, especially since I'm going to end up buying another 958.
As with others, interested in a write-up on the process.
Looks like I will be following you with my own 2013 GTS! Couple of questions:
-Michael
- How hard was it to remove the case from the car? Anything funky other then removing a lot of bolts? Did you follow a manual for instructions or just have at it?
- What was your parts ordering process with the company from Europe?
- Did you reset any of the parameters in the control module or update the firmware as was commented on in the sticky thread on TC problems?
- Did you install the other parts that were listed on the worksheets from other members that had their TCs replaced on warranty by Porsche?
- You have a 1" chain. Did you consider changing to a model that had a 1.25" chain?
- What was the hardest part you encountered in your rebuild?
- Did you write up a DIY?
-Michael
I'd be interested as well. I have my parts. Ordering from Andrew is pretty straight forward just make sure he has your case serial number or you could get the wrong chain. My # indicated a 1.25" chain. Fingers crossed.
Decide if you want a seal kit and expedited shipping. My answer to both is YES. You may not need the seals but if you tweak one you'll be glad you have it. The shipping by Fedex took TWO DAYS for 20 extra euros.
I'm looking it over right now. Aside from wiring connectors, shafts, and bolts there's not anything in the way - except the exhaust. It may have to come down, not sure but it's preventing me from seeing the shaft at the rear end real well. The rear shaft is long. I'm most interested in seeing how it is removed right now. I cannot see any normal coupler with bolts. Absent this I can only guess it has spring clips on one or both ends and has to be dropped from the center support? Would love to see clarification.
Really trying to determine if I am doing this or giving it to a tranny guy who's quoting me about a grand for R&R using my parts. I'm happy to do it myself but time is money and I don't have a lot of time for this to be down.
Too bad the vent kit wasn't added to the rebuild process.
WHERE exactly is the case serial number? I was changing the fluid this weekend and had a good look around the case... obviously not good enough as I didn't see ANY #s at all. Pics or it didn't happen!
Received 1,160 Likes
For people thinking about rebuilding - you might take a look at: https://rennlist.com/forums/cayenne-...l#post15317086 - it would be interesting to hear what adding this to a few cases bad enough to need rebuilding does.
It's available all over the interwebs, and probably your local Ford dealer's parts department or at least any NAPA store. And it stinks.. read the reviews.
well, my rebuild lasted longer than the original transfer case!!! Started showing symptoms a few weeks back and now I can't get it out of my head. It does have almost 125K miles on it now though.
10 year warranty runs out in December so I stopped by the dealership this morning and set an appointment for next Friday. I'll let them take care of it this time
Has been a great car and I haven't done much to it other than brakes and fluid change. Still thoroughly enjoy driving it and would keep it over my 911.
The following 4 users liked this post by e30rapidic:
Rebuild or Replace
I’m new to the 958 fraternity - just bought 1 owner, dealer maintained, 2012 CTT with 173K miles. Never had transfer case replaced.
Despite a PPI clean bill of heath by reputable local Porsche independent - I believe to now have beginnings of transfer case slippage - low rpm rumble when cold and pulling 1st and 2nd gear / no rumbling after warmup period and no signs in other gears.
TC and full transmission service was done 7,500 miles prior so I’m assuming a fluid change won’t delay the inevitable.
For peace of mind and since it’s my daily, Im considering buying replacement OE Transfer Case from FCP Euro with lifetime warranty and installing myself. I have access to a 2 post lift.
After installing FCP Euro unit. - rather than returning the original TC as core (loose FCP’s $300 core charge), simply rebuilding the original and selling on eBay/Rennlist to recoup some cost.
Any critique/thoughts of wisdom on this game plan?
Also, can anyone confirm - since my 958.1 is 2012 with 02/12 build date it’s no longer covered under Porsche 10 year extended TC warranty?
Eric
Eric
Eric
Eric
Thanks for the guidance - just checked original warranty book and in service date was 3/28/12 so looks like out of warranty / maybe take it by dealer to see if they would consider exception or if they just laugh me out the building
Maybe I jumped the gun on diagnosis - the hesitation is alway at cold startup with car starting on slight incline but have noticed it during parking or low speed turns.
Any thoughts on what else to consider? Seems to be coming from driveline
