2016 CTT PCM fuse location ?
Looking for the PCM fuse in the online manual, no luck just one reference to the right side fuse box on location # 51 but tagged with (Japan)
Received 1,150 Likes
Not sure what you mean by "Japan" - but the wiring diagram power distribution diagram shows #51 in the right side fuse box as the power source to the PCM.
What does "(Japan)" mean - is that marked on the reference? I suspect you can ignore it if you have a left-hand-drive Cayenne
What are you trying to accomplish?
thank you for the help, now and in the past you have been great cheers.
will check it out tomorrow when i am back home.
http://knigaproavto.ru/shemy/en/pors...e-cayenne.html
was just looking online, as you can see there is (Japan) word on the same line as the fuse number location so was not sure.
I need to remove the PCM without disconnecting the battery, going through installing carplay interface as in here
https://www.youtube.com/watch?v=RF_k...ature=youtu.be
following these instructions here
https://www.dropbox.com/s/q1q41cxz2v..._v1.4.pdf?dl=0
