TPMS Programing
Can you program out the TPMS function from the car? I have some BBS wheels that do not accept TPMS that I would like to use without the warning lights in the dash.
I wonder what would happen if the TPMS control module was simply unplugged from the CAN. Probably throw an error code but it shouldn't cause a CEL. Easy enough to try at least.
It'll throw an error if you just unplug it, too.
I'm sure the PIWIS can disable it, though the dealer might not be willing to do it since it means they might also then have to accept liability if something happened. It's a federal government mandate that all cars sold in the US after ~2008 (? I think) have tire pressure monitoring systems. It was a reaction to the Ford Explorer rollover problems with tire blowouts IIRC. Since it's a "safety" item asking a dealer to code out TPMS is probably going to be met with the same response as to a request to code out airbags, the ABS system, the CHMSL, etc.
I can tell you that, on my 987 Cayman, using a DuraMetric Pro (a "cheap" version of the PIWIS that can do some of the PIWIS functions) I was able to code out the TPMS system. To my knowledge though, you can't do any coding with the Durametric on a 958 Cayenne.
If I were to get a set of TPMS, have them installed by a non Porsche dealer, I'd have to go to either a dealer or an indy that has a PIWIS to have the TPMS coded?
Would the swap to another set of wheels that are already coded to the truck need to happen again, from say the winter set to the spring/summer/fall set?
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/651x287/182833544_ca12b0d24fc0cd3ab440235d87e4cf025a389019.jpg)
The TPM control unit with integrated antenna is fitted on the outside on the vehicle underbody. The control unit is water-tight. The underbody panelling serves as mechanical protection for the control unit. The location of the control unit on the outside of the vehicle ensures that wheel electronics reception is not subject to interference as a result of various conditions in the passenger or luggage compartment or due to metallized heat-insulating glass.
True. If you purchase OEM/compatible sensors, the vehicle will pick them up automatically. I do this with my two sets of wheels/tires for summer and winter. I just input the change in rim size and tire type in the menu, then drive off.....before I'm at the end of my street they're set.
Exactly.. Being able to reset the TPMS is the one "gift" they give us DIY'ers. My wife's Subaru takes a $150 tool to do the same thing for the TPMS sensors, but no issues with an oil change indicator. Go figure!
Also, you might want to do some debugging before you start replacing modules... (error codes, battery and sensor age, etc...)
