Temp Display Defective
How much does it cost to replace the thermostat/housing on the V8 at the dealer? My '12 CS is exhibiting all the symptoms with the CEL. Also, when I asked the dealer about pinning the coolant pipe, they are not exactly familiar with it. Thanks for any help
I am late to this party but thought I would throw in that I was having the same issues with my 2014 Turbo S Cayenne. I had the front and rear temperature sensors replaced and it made no difference (except for the $1300 I spent). I then decided I would tackle job 2 myself and replaced the thermostat, water pump (perfectly good one), serpentine belt (42,000miles). Other than having to 'burp' the coolant until full, as I did not use the vacuum system as I really should have, it worked well. Running temp is 200 F. If someone could confirm that temperature as a proper one, I'll be all done!
