Odd sound / mild vibration coasting
Happy New Year to All !! Found the wife a nicely optioned 2014 Cayenne GTS with 52K back in June, our first Cayenne and it's been great for 7K miles of our ownership. Recently had a 'squeaking' fan motor, but it was pretty easily remedied by cleaning out the motor and applying a little spray grease. Based on others experience, I expect this will need to be replaced in the next months/year, we'll see.
Given this isn't my primary driver, my experience is limited by my personal drive time. However, I have noticed an 'odd' sound and 'feeling' upon release of the accelerator pedal (right after getting off the gas) while the vehicle is 'coasting'. It almost sounds like there is a 'drag' on the vehicle that's not usual, at least based on my experiences. This happens before brakes are applied, just after letting off the gas, while coasting. Thought it might be tires (on the 21'' turbo style wheels), but recently changed over to a winter setup with new rubber. Same sound / feel. I do not feel like this has anything to do with the Transfer Case, but I did want to mention that I changed the fluid (twice) in the TC upon reading all of the feedback on rennlist. Acceleration is smooth, no turning or crackling issues (before or after the fluid change).
Curious if anyone can relate to this issue or have a similar feel when they decelerate? Any thoughts on the topic?
'13 GTS here..
We have had ours for almost a year and 11,000 miles
I do experience the same thing you are describing. I am starting to think its normal. At almost any speed, allowing the car to coast results in noticeable scrub of speed
Also, when starting out for first drive of the day, putting the car in drive after reversing from drive way, results in a slight hesitation followed by a slight jerk forward. Been to Porsche dealer twice and master Mechanic claims its normal.
He claims its the result of the beefy traditional transmission (shared by Turbo and Turbo S). We were an Audi family for 15 years and there IS something familiar about the transmission characteristics.
It could be transfer case acting up so we will see.
Keep us posted
Keep us posted
If it the black GTS out of Buick dealer in Milwaukee?
I test drove it this summer and heard the exact thing you described. Told the seller about it and they claimed to had checkout by Porsche and came back as everything is fine.
I drove other GTSs and bought a different one - none are making any noise when you let off gas
For sure it's not normal - in few GTSs that I checked out only 1 was doing it and it is indeed hard to notice. Try following R553's suggestion and replace diffs fluid
Thanks for the suggestions. Curious how to check the drive shaft bearing? What am I looking for?
For the starters you could try this drive shaft thread although it is from 955: https://rennlist.com/forums/porsche-...with-pics.html
And ultimately: http://coloradodriveshaft.com/porsche_cayenne.htm
