GTS Brakes - Big Reds?
Not 100% sure about the GTS but they are definitely big reds o my 09 Turbo S. If the replacement part number is the 19" rotor then they are big reds. Otherwise they are just red brake calipers.
Generally speaking "Big Reds" traditionally refer to the 964 Turbo 3.6 / 993 Turbo Calipers. These were / are a very common upgrade on 911/944/928/968s. Yes your brakes are big, and yes they are red
Also worth noting your GTS brakes are LARGER than these
My understanding is that these sizes (330mm and 350mm) are not big reds. The big reds are the 380mm found on the Turbo S models. I actually took my big reds off my 09 Turbo S and put on a full PB 8 pot brake kit. Slightly more than OEM replacement but it looks great and has incredible stopping power compared to OEM. Besides, you don't want to mess with the 380mm rotors so be glad you have the smaller. They are very expensive and extremely heavy to work with.
My 09 957 Turbo S has 380x38 mm front rotors and the large red calipers too
I'm installing a set of PCCBs on mine in the next couple months once the widebody conversion is completed - virtually no dust and probably no brake work for the life of the vehicle (maybe a set of pads at 80,000-100,000 miles or so). I'll be putting my OEM brake kit up for sale at that time - 28,000 miles on them.
I looked all over the place. Woulda, shoulda, coulda.
