"Stuttering" steering...?
We are having a roadtrip in Europe and I notise when I park having to turn the wheel standing still, the steeringwheel stutters.... you can hear and feel its uneven in its movement.
I have to add that the steering seem also abit heavy at times.... but its suttle diffrences. Then I had a look at the belt running the pump and its worn and cracked... culd this be the culpit of my problems? Maby the belt slips at times? I had similar on.my Corvette C5 and that was worn serpentine belts...
Possible?
Possible?
My tiresis worn out P Zero from Pirellie. But im not con inced its normal? If so these are the only car oft the100+ iv had who do this. Its probably also the heavyest but still I thought Porscha knew how to build cars? Its not a Kia this :-)
Received 1,144 Likes
Very normal. Porsche tried to fix my '06 Tit/S - replaced the power steering pump, steering reservoir, steering rack. Nothing changed. It may be partly the rubber mounts the steering rack is held to the frame with - but whatever - after replacing most everything, my '06 still did it. Never caused a problem. My '11 CTT doesn't do it.
Caveat... if it is excessive and feeling it at higher speeds, definitely have it checked out.
I've noticed this in the Cayenne's I tested recently. One thing I noted is the front end moved side to side like the wheels are offset from the pivot point. I think this coupled with very wide tires would cause this.
