How can I troubleshoot a misfire without durametric?
Old 06-28-2016, 11:37 AM
Shawn Stanford
Shawn Stanford's Avatar
Default How can I troubleshoot a misfire without durametric?
This is kind of involved, so bear with me...
A couple years ago I replaced the coilpacks and plugs in my '05 V6. Since then, every once in a while one of the replacement coilpacks just daggone melts. My solution has been to simply pull it and put back one of the original coilpacks, which I luckily kept. As stupid as this sounds, it's been working. My P!g has about 140k on it and runs great.
This morning, another of the replacement coilpacks went south and I did the usual: I replaced it with one of the original coilpacks. This was on the frontmost cylinder (#1? I'm not sure.). However, on restarting the truck, I still have a miss. I'm not sure if it's the same cylinder or if another cylinder is giving me trouble.
The question is: Is there a way to determine the cylinder with the miss without a Durametric? Someone in my PCA Region has a Durametric, but I'd rather figure it out myself and save him the drive.
Old 06-28-2016, 12:19 PM
Wisconsin Joe
Wisconsin Joe's Avatar
Unhook each cylinder one by one and see which one doesn't make it worse?
Standard practice on engines with standard plug wires. Not sure how practical it is with this setup.
Old 06-28-2016, 12:51 PM
deilenberger
deilenberger's Avatar
Received 1,153 Likes on 764 Posts
If you go this route - disconnect the feed wire to the coil. Do not remove the coil from the plug. Firing a coil that isn't connected to a plug means it has no path to ground for the ignition pulse. In that case - it creates a path to ground back through the primary side of the coil, potentially destroying both the coil and/or the ECU that drives the coil.
So - disconnect the power feed wires to the coils one by one. I'd start with the one you replaced.
Old 06-29-2016, 08:58 AM
Shawn Stanford
Okay, so I remembered that I have 'Automatic' and that it throws codes. I fired up Finn and Automatic gave me a code for cylinder 'A'. I noticed one of the connectors on the plug looked a little 'toasted' yesterday, but this seems like confirmation. So, it looks like I need to replace the connector.
Old 06-29-2016, 09:16 AM
Shawn Stanford
Found this video:
Old 06-29-2016, 06:11 PM
Shawn Stanford
Ordered these from Amazon:
Quick Reply: How can I troubleshoot a misfire without durametric?
