Porsche Cayenne S 2011 Bluetooth audio cuts out
Hi Cayenne forum,
Car: Porsche Cayenne S 2011 w/ Nav.
Problem: When listening to music from my phone via Bluetooth the music will cut out for a split second. This happens about 10-15 times per song! It has become very annoying (especially if you like to sing along LOL)... I have tried multiple phones and devices and they all do the same thing.
Would a firmware upgrade to the unit help? When I go into the stereo and select "system version" I see 2.7... Does this mean I have a 2.7 PCM? Does anyone know what I could upgrade to?
Also thinking of replacing the head unit all together. I see outfits selling head units for my car with 3.1 PCM. But again I'm not sure if this means I will be upgrading my unit and if it will even work.
I have scoured the internet trying to find a solution to this and at the end of my rope here.
Thanks in advance.
Thanks in advance.
Try turning off wifi on your phone and see if that helps. Worked for me. I have received an Pcm update recently but haven't tested it yet to see if the upgrade fixed the problem.
Thanks deilenberger, I found your other post where you mentioned the PCM upgrade and replied to that also. I did not find anything on http://www-odi.nhtsa.dot.gov. Do you have any more information on it that I can take to the dealer? Thanks in advance.
Texas993, I have already tried that. But thanks for your reply. its appreciated.
Received 1,160 Likes
And if you're registered with Porsche-US you should be getting notices of things like this (like the pedal-cluster recall too.. the most recent one.)
So I called the dealer and gave them my Vin#. They claim my car is not affected by WF27. I'm pretty sure it's because they don't want to do it. Is there a way I can make them install it? that is, if it's compatible with my car of course. Not sure if "Bluetooth cutting out" would be enough for them.
I went ahead and registered with http://www.porsche.com/usa but not sure if I will get any letter. :-(
Anyhow I will keep trying.
Thanks,
Sergio
Thanks,
Sergio
Thanks,
Sergio
Thanks,
Sergio
http://www.porsche.com/usa/aboutpors...snorthamerica/
Porsche Cars North America
1-800-PORSCHE (1-800-767-7243)
That's assuming you're in North America (it might be useful to fill out your user profile so we would know this..) If you're not - find your local Porsche importer/company/whatever and use the phone. You'll get an immediate response that way.
